View Full Version : Dead Machine Konica Minolta bizhub C224e replace MFP board
Arko289
08-13-2021, 05:29 AM
Greeting. The old MFP board was damaged and I bought a used one. Do i have to put firmware in it or just install it in the device? The SSD and print control board remains old.
Konica Minolta bizhubC224e
tsbservice
08-13-2021, 06:30 AM
You will need FW and Reset tool PLUS following the exact procedure.
Arko289
08-13-2021, 08:05 AM
Thank you.
Where I can find firmware?
Already have Reset tool
avecosat
08-13-2021, 12:27 PM
www.copierfirmware.co.uk (https://www.copytechnet.com/forums/redirect-to/?redirect=http%3A%2F%2Fwww.copierfirmware.co.uk)
Copier tech will help you
escalante
08-13-2021, 12:47 PM
Thank you.
Already have Reset toolGood morning. What firmware version do you need?
Enviado desde mi Infinix X692 mediante Tapatalk
Arko289
08-14-2021, 08:25 AM
The last one, I don't know which one was on the device because the motherboard was damaged. It is important that it works on bizhub c224e
copier tech
08-14-2021, 08:33 AM
Thanks, see attached procedure.
49939
