View Full Version : Konica 7135 black copies
tander47
12-03-2008, 11:39 PM
Hi
i have a konica 7135 and when i try to make a copy by putting the original on the glass it comes out black. But when i use the adf the copy comes out great.
I was thinking it might be the ccd or the scanner driver board.
Please help.
smiley
12-04-2008, 01:46 AM
maybe your scaner unit are disaligned.try to change ccd board. gud luck.;)
dogsbody
12-04-2008, 06:23 AM
your scanner is in the right place when using the RADF but something is knocking the mirrors out of place when they move out to scan the page on the platen. you know the ccd is working because it works with the RADF.
montana
12-04-2008, 12:06 PM
hi.when you make copy by the feeder the ccd is fixed not moving.&when you put the original on the glass the ccd is moving to read the original .you can check the movement of the ccd by naked eye if it is correct movement or not.
thanks for all.i hope it is helpfull
montana
12-04-2008, 12:16 PM
hi everybody.is there anyone coulad tell how to go through servicemode in (konica minolta bizhub 250)
thanks
Luther
12-04-2008, 01:57 PM
The ccd is in a fixed position , the scanner or optics move, i would say check the movement of the mirror assembly from left to right, either they arent moving correctly or a mirror is out of place, good luck
ni311
12-04-2008, 03:15 PM
utility/counter - > details - > [STOP][0][0][STOP][0][1]
eg101
12-04-2008, 09:21 PM
I've seen the mirrors get out of alignment before, check the height on the rear of the mirror carriage.
eg101
12-04-2008, 09:28 PM
utility/counter - > details - > [stop][0][0][stop][0][1]
utility/ counter/ detail/ stop/0/0/stop/0/1/ 0/0/0/0/0/0/0/0/ end
tander47
12-05-2008, 05:31 PM
Thanks for the help Smiley
I will try that
tander47
12-05-2008, 05:34 PM
thanks dogsbody for the help
I will check it out
tander47
12-05-2008, 05:35 PM
thanks montana I will check it
tander47
12-05-2008, 05:39 PM
thanks for the advise Luther. It looks like the mirrors are good for some reason I think it might be the ccd board or main board.
tander47
12-05-2008, 05:42 PM
thanks for the reply eg101. everything checks out on the mirrors
ni311
12-06-2008, 09:16 AM
Wasn't much easier to thank everybody in just one post?!
