View Full Version : Miscellaneous How to disable the scanner in konica minolta c6501
vijaysharma
08-23-2021, 07:56 AM
Hi,
I want to disable the scanner in c6501 can any one able to suggest which dip sw solve this issue.
thanks in advance
Synthohol
08-23-2021, 12:32 PM
take a hammer to the lamp ;)
copyman
08-23-2021, 12:34 PM
Not familiar with that model but most Kon/Min have "isolation" tab in service mode under system 1 or system 2. "UNset" what ever you want to disable.
bsm2
08-23-2021, 12:43 PM
You should be able to remove the scan icon from the control panel.
If you don't want walk up copies turn on account codes.
vijaysharma
08-24-2021, 07:05 AM
This is Production category machine, Therefore, this machine does not have isolation mode, instead it can be turned on or off with a software switch.
thanks for reply
