View Full Version : C554e toner refill
Amrss
08-24-2021, 12:33 PM
Hello everyone,
is it possible to refill the konica minolta c554e cartridges with toner specific for press machines like the 1070 or 3070 ( this one specifically Konica Minolta TN619 Toner Set for bizhub PRESS C1060 C1070 Part Number: TN619 4-Pack (https://arcservicesco.com/konica-minolta-tn619-toner-set-for-bizhub-press-c1060-c0170) ), would I face any problems if I did that ?
I want to do that as it can be a lot cheaper than buying the genuine toner specific for the c554e machine.
Phil B.
08-24-2021, 12:54 PM
Hello everyone,
I want to do that as it can be a lot cheaper than buying the genuine toner specific for the c554e machine.Compatible toners can cause all sorts of problems from CQ to premature failure of parts.
Do what you want but I'd stear clear.
Amrss
08-24-2021, 01:04 PM
sorry but, CQ stand for ? :confused:
would those problems occur even if I refilled with genuine c3070 toner ?
Phil B.
08-24-2021, 01:32 PM
would those problems occur even if I refilled with genuine c3070 toner ?CQ = copy/print quality.
As far as I know they do not sell bulk toner powder.
Amrss
08-24-2021, 01:37 PM
If I emptied genuine toner cartridges specific for the c3070 in the c554e cartridges, would that cause any problems ?
Is the toner material the same for both machines?
patrickjlc
08-24-2021, 01:45 PM
I had issues with refilled/ aftermarket toners. You might save some money on the toner, but drums are expensive if messed up with non original toner, learned that the hard way....
Sent from my motorola one 5G UW using Tapatalk
Amrss
08-24-2021, 01:53 PM
Would those problems still happen even if I refilled with genuine toner specified for a konica machine other than the one I have ?
copyman
08-24-2021, 02:03 PM
Some of the toner is same, for instance all the 4 series is same. I wouldn't use a different series toner. Like the other poster said why ruin the drums with wrong toner. Forget about the drums, what about contaminating the developer units with wrong toner, dev units cost $500+ each!
Amrss
08-24-2021, 02:19 PM
Got your point, would be interested to hear what others say or if anyone tried this
Thank you so much sir
emujo2
08-24-2021, 02:46 PM
The very fact that there are 100 different toner bottles out there for the current fleet of machines drives me f'ing nuts..One bottle to rule them all!!!..Of course, production and KM branded devices are going to be different, and I understand the corporate level need to keep out knock off supplies as this affects their bottom line. IMHO if you are having to resort to filling up toner with the left overs from other devices you are probably not going to last much longer. E
allan
08-24-2021, 03:39 PM
The Materials Safety Data Sheets shows that the toner composition is not the same.
TN619 contains organic pigment and there are too many differences.
Here compare the MSDS for yourself.
MSDS TN512K.pdf
(http://sds.staples.com/msds/2075177.pdf)MSDS TN619K.pdf (https://www.copy-center.de/images/download/umwelt/MFP-2944-C1070-C1060.pdf)
I always check this first before using other toner. But does not mean that it will not work.
Amrss
08-24-2021, 03:42 PM
Appreciate the reply sir
Amrss
08-24-2021, 03:46 PM
Here compare the MSDS for your self.
MSDS TN512K.pdf
I see, since there are differences I don't think it's worth it to risk damaging the drum units or the developer units
Thank you so much
Zesti
08-25-2021, 09:57 AM
Hello everyone,
It will give excellent result... provided toner is OEM..
Be carefull not to refill in humid environment...
Amrss
08-25-2021, 10:21 AM
Thank you for your reply sir
Have you tried doing this on konica machines and what were the models used?
Zesti
08-26-2021, 07:56 AM
We are using BH Press C8000 toner (TN615) in 4 series machines and other BH models.
mascan42
08-26-2021, 12:41 PM
At the very least, I would expect this to cause fusing issues since the different composition of the toner can have different fusing temperatures.
Amrss
08-26-2021, 06:33 PM
Have you faced any particular issues since you began doing this ?
Zesti
08-27-2021, 02:36 PM
Nop.....excellent running...give it a try.:cool:
tulintron
08-27-2021, 03:02 PM
We are using BH Press C8000 toner (TN615) in 4 series machines and other BH models.Here in Brazil they adopted this C8000 toner. Developers are gone very quickly.
rpesa
08-27-2021, 03:25 PM
I am using for a while TN622 It is giving a good color quality but I have seen a slightly yellowish background on plain paper on one machine.
The original toner for C554e has developer inside compared with TN622.
Any suggestion?
