View Full Version : Jamming C654e Fs534SD
big jase
08-24-2021, 04:08 PM
Hi
Strange one, jams 72-19 in finisher but only when doing a double-sided job and only when a full darker print is on the 2nd side
Albonline
08-24-2021, 06:05 PM
Hi
check the fans and filters in the cooling system, sounds like toner may be sticking to things in the inversion/exit units.
tech51
08-24-2021, 08:11 PM
Hi
A colleague of mine had something similar. He physically cleaned all the sensors with alcohol rather than just blowing them out.
The customer was using originals with a dark background.
Worked for him!
allan
08-24-2021, 08:14 PM
Paper curl issue? Try dropping the fuser temp to see if that helps.
blinxwap
08-28-2021, 06:53 PM
Hi
Strange one, jams 72-19 in finisher but only when doing a double-sided job and only when a full darker print is on the 2nd sideClean or replace the exit/entrance sensor on the finisher
Sent from my SM-A725F using Tapatalk
