View Full Version : Konica c454e Firmware (the job has been deleted due to insufficient memory)
chuyno
08-30-2021, 10:10 AM
Hello,
I have problem with konica(the job has been deleted due to insufficient memory)
I want to upload firmware.
Could someone upload a link to the firmware or send me it in a private message?
Thx ;)
MFP Controller: A5C10Y0-0100-G20-M1(00)
copier tech
08-30-2021, 12:18 PM
Hello,
Thx ;)
Happy to help with this firmware. You can contact us at the links below.
ltdiniz
09-01-2021, 12:44 AM
Just access Technician mode and Enable Equipment HD if it is disabled.
After that it formats the physical and Logic HD that can solve your problem.
Does it refer to scan jobs in combination with highly compressed compact pdf? In case it does: Turn off compact PDF and try again, you'll end up in this message pretty quickly if you try too many and/or complex originals. I got calls about this every now and then - I think there's also a bulletin available with some SP tweaks but can't recall any specifics, there's probably already a topic here @CTN ;)
