View Full Version : c658 pulling A3 back into exit section on double sided
ralleyman
09-09-2021, 10:55 AM
hi i have a C658 that whn doing double sided A3 it is picking up a sheet that has just come out when turning the paper over then causes the j3205 code, there is no finisher on this machine has anyone come accross this issue before.
I have tried changingfuser temp and also it is a lot better if you set the paper to thick 1 but there is an occasional paper sticks in the exit but does not give a jam
kingarthur
09-09-2021, 12:30 PM
If it has no finisher...has it got an OT fitted.....
ralleyman
09-09-2021, 12:48 PM
Yes it has the output tray it looks like there should be anbother tray between the top and botom exit on the exit assembly
srvctec
09-09-2021, 05:41 PM
Sounds like you're missing the output guide that came with OT.
https://uploads.tapatalk-cdn.com/20210909/42a1f004e03360e7ed386d9f9b873e96.jpg
Synthohol
09-09-2021, 09:37 PM
When using an output tray there are 3 half moon rollers that attach to the exit shift
Sounds like they were never installed (not needed if there is a finisher)
Error
Jam 32-05, paper is curling up in the output tray after a few pages.
Root Cause
Some of the rollers included in OT-508 were not installed.
Workaround/Fix
Ensure all procedures are preformed during the OT-508 installation (see attached).
https://www.copytechnet.com/forums/attachments/konica-minolta/50109d1631220643-c658-pulling-a3-back-into-exit-section-double-sided-exit-jpg
B0265
09-10-2021, 07:27 AM
The OT-508 is for the C759/C659, the OT-506 only includes the parts in srvtec's picture.
Synthohol
09-10-2021, 12:53 PM
from the knowledgebase...
Jam 32-05 when exiting paper to the output tray OT-508
Known Error
Related Products:bizhub C659,bizhub 658,bizhub 808,bizhub 958,bizhub C658,bizhub C759
Related Options:
B0265
09-10-2021, 03:03 PM
I think that must be a mistake, the eject rollers are different in the C658 compared to the the C659 so the extra rollers would not fit even if they were included in the OT-506.
