nelo
09-14-2021, 05:52 AM
Hi All, this Pro 1100 causing paper jams 3301 & 3302. paper jam codes for the fuser unit area. The fuser unit has been service 2 weeks ago and I also tested it on another Pro 1100 and works perfectly. I pulled out the ADU and have observed the Transfer Belt shifted to the rear end. If I realign the belt and do copies / prints, it works ok however paper jams again when the belt shifts to the rear end of the belt unit. If I pull out the belt assembly and turn it by hand 10 or 20 rotations the belt will slide / shift to the rear end.
The belt it self is new, fitted 2 weeks ago on PM service. The belt frame was not changed.
I did paper adjustments for all trays and also did leading edge adjustments. Cleaned the ADU paper path, belt cleaning unit, registration rollers & sensors, conveyance rollers and also did adjustments where necessary. I also did the front rear registration adjustments.
I have not changed the belt holder / frame but cleaned and lubricated bearings & contacts. Have not tried firmware.
I am thinking there may be a specific tech support document for this issue but cant find any.
if any one who have come across the same issue can share some ideas on this.
Regards
Regards
