I have a bizhub c350 that stopped printing after being off for about 2 months. The IP address ping returned a failure 100%. The driver was uninstalled and reinstalled but no change. The network light blinks and seemed normal no error message. Does anyone know what the matter is and how to fix this problem.
network printing
Did you reset the IP address in the machine ?The greatest enemy of knowledge isn't ignorance, it is the illusion of knowledge. Stephen Hawking -
I'm going to -guess- that you were pinging from the customer's computer already on the network. Is the copier on the same network and subnet (address) as the computer you were pinging from? Can you ping the copier from a (properly configured) laptop using a crossover cable?
You will get ping failures if there is another device on the network using the same IP address. It would be unusual for there to be 100% failures. But, I'll bet you only ran 4 pings thus its possible for all four reponses to be corrupted. A quick check would be to disconnect the copier and rerun the ping test. The point being that the copier was off for so long it's IP address could easily have been assigned to another device.
Also, you could check that you can ping some other device on the network from that same computer just to rule out something odd happening.Comment
amionaho
amionaho
I have troubled shoot this machine with your suggestion. The controller is funtional from the pad but not from the PC. Any idea how to fix?Comment
first reset to factory defaults the network of the machine
if the problem continuous try to update the machine the latest version is 46
good luckComment
IP address
My suggestion: If you can get into the PRINTERS setup through its control panel, quiry what IP address the printer thinks it needs to be.
Then go into the computer, printer settings, highlight the printer,right mouse click, go to properties, find the connection tab and locate what IP address the computer THINKS the printer is and change it to the new one, restart the computer. This works for Windows XP.Comment
