View Full Version : Kyocera Fs-2100dn unable to connect to PC
rapidocument
09-18-2021, 03:58 AM
Got this Kyocera Fs-2100dn to service at my shop (Heat roller change), tried to connect it via USB cable
using the Universal driver from Kyocera but I have been unsuccesful so far.
I am wondering if there is a dedicated driver for this machine?
I have two PCs one with win7/64 and the other win10/64 problem is in both
I have used different USB cables too without success.
Thanks for your inputs on this,
Jaime.
blackcat4866
09-18-2021, 01:32 PM
I'd suspect that the USB connector is damaged on the main PWB. Did you try connecting via the network interface?
And no, it's not a dedicated driver. The Universal will work, if it's able to. =^..^=
JR2ALTA
09-18-2021, 04:35 PM
Jaime.
Does your computer detect a new device?
rapidocument
09-19-2021, 06:15 PM
Yes, when I connect the USB cable the PC detects it.
JR2ALTA
09-19-2021, 06:34 PM
Have you played around with the different USB ports in the driver properties? USB001, USB002 etc? Might be easier to use the Wizard installer vs. pointing to driver file.
PrintWhisperer
09-19-2021, 09:02 PM
Good advice and it points to the problem with USB in that every time you plug in you may get a different USB port number and have to change the driver to match.
It's OK for dedicated connections where there aren't a lot of changes.
Using the Printer Install wizard select the 'choose existing ports' option and select the USB port number it is occupying. (Delineated printer ports can be viewed from the Print Management MMC under the PORTS section)
In the Driver step, choose from the manufacturer's driver list for Kyocera and find your device that way. This will give you the MS provided Unidriver selections (this is not the Universal Driver) and any KX drivers in your driver store.
The Universal driver is not a 'dedicated to one printer/port driver', it polls available printers using mainly network protocols and I am not even sure it supports USB.
Cause, well, USB :barf: is for thumbs and HID
