View Full Version : Konica Minolta C454e IC CARD Reader Driver
SKchadburn
09-22-2021, 04:59 PM
Hi can anyone help me i have the C454e but the HDD went Kaput, I have now replaced the HDD ,updated the Firmware and reinstalled the video file but the IC card does not work any more, i did read that it may need a driver?
Kind Regards
Simon
blackcat4866
09-22-2021, 10:45 PM
What kind of card reader is it? Yes, it matters. =^..^=
SKchadburn
09-23-2021, 05:29 PM
5022250223
thanks for answering im unsure as its inside the front panel but when i removed the front panel it was just double sided taped to the door but i could find no part number on it it just plugs into the USB port next to the Ethernet port though i can try and disassemble the plate if you require it ?
Thanks Simon
tsbservice
09-23-2021, 07:16 PM
5022250223
Thanks Simon
Check in service mode under Firmware version to see if any Loadable driver is installed and which one if listed.
blackcat4866
09-24-2021, 01:51 AM
He had to change the hard drive, hence no Loadable Device Driver, and no proof of what driver it used. =^..^=
rrrohan
09-24-2021, 05:14 AM
looks like HID
unclip it out of the mount so u can read stickers
avecosat
09-24-2021, 01:14 PM
You need A5C10Y0-A521_G00-01_Y-Soft
