View Full Version : i need schema how to make reset
Abdo98
09-26-2021, 01:30 AM
i need schema how to make reset unity drum and develop
Phil B.
09-26-2021, 02:51 AM
i need schema how to make reset unity drum and developPlease explain your problem more clearly.
tsbservice
09-26-2021, 10:13 AM
Agree with Phil. Most of Konica Minolta machines have drum and developer chips. You may find some aftermarket chips and even reseters I believe.
Abdo98
09-26-2021, 01:48 PM
50240
Possible way to make like in the picture
allan
09-26-2021, 10:08 PM
What machine model???
Phil B.
09-26-2021, 10:14 PM
50240
Possible way to make like in the pictureSure with the right:
Circuit board.
All the parts and assmbly instructions.
Or
Just BUY what you need.
This thread is done IMHO.
No pm's either.
Abdo98
09-26-2021, 10:15 PM
c224/c284/c364/c454
Abdo98
09-26-2021, 10:18 PM
Circuit board.
Or
No pm's either.
I did not understand what you mean
allan
09-26-2021, 11:58 PM
c224/c284/c364/c454
You can just get aftermarket replacement chips.
Or replace the fuses on the chips.
Or make a reset tool where you can use glass fuses instead of the SMD fuses.
Plugs in like the tool in the picture.
Done all of the above with success.
The Fuse from a TN512 toner bottle is the same, you can desolder them and solder them on top of the used chip.
allan
09-27-2021, 12:01 AM
For drum chips the fuse is between pin 1 and pin 3.
For developer chips the fuse is between pin 1 and 5.
Just trace them back to the front-side PCB.
Abdo98
09-27-2021, 12:37 AM
