View Full Version : Scan to mail for human being in C3320i
olivenoire
10-03-2021, 03:00 PM
I do often need to scan to mail in 3 to 4 contacts many times a day. (that it)
Actually I need to :
- select the first mail
- then select "add dest" (useless)
- Then select the added dest
- Then validate (useless)
- Then close the message (useless)
once again for the third dest etc etc
Can't find a way to do it faster the same way on Ricoh (simply select multi dest) nor user, admin or CE menu
Any help?
Synthohol
10-03-2021, 04:22 PM
create a group?
copier tech
10-03-2021, 11:35 PM
Any help?
You can set multiple scan destinations in: Admin settings>security>restrict user access>multiple address settings>disable.
olivenoire
10-04-2021, 10:50 AM
Hey, thank you.
Just crazy I did not find it after research.
copier tech
10-04-2021, 12:48 PM
Hey, thank you.
A few of my clients complained about this "My old machine I could select multiple email contacts"
I got this setting from Konica Minolta.
olivenoire
10-04-2021, 01:11 PM
Anyway, thank you for sharing!
olivenoire
10-05-2021, 07:38 PM
I’ve find something no exactly in this submenu.
believe me or not, when an another recipient is added, an information box appears and need a touch to close.
probably an another setting in deep submenu
konica UI is absolutely finish and pain in the ass to use.
nothing to compare with Ricoh (a printer I can decide to print 1 or 2 sided)
tsbservice
10-05-2021, 07:51 PM
Those were prone to some toner eatings, premature IU failures etc. I will call it success for not doing above and move on. About right time to plan your next A4 color mfp purchase.
olivenoire
10-05-2021, 08:06 PM
you are right
