View Full Version : fuzzy lines in images
rrrohan
10-19-2021, 03:20 AM
Im getting fizzy lines through prints.
50439
Its not the MFP sadly. Would you say A7PUM40800 High voltage unit is the next best option?
Synthohol
10-19-2021, 03:32 AM
do the internal test prints do the same? (halftone and gradation test patterns.)
rrrohan
10-19-2021, 04:46 AM
That is the internal test bird. And halftones do same yes
Sent from my Pixel 4 XL using Tapatalk
tsbservice
10-19-2021, 07:02 AM
Before start throwing boards I would remove any option and try.
Albonline
10-19-2021, 03:36 PM
judging by the limited info, i would say print head. seeing half tone patterns would be a great help.
Synthohol
10-19-2021, 04:35 PM
Fwiw I've seen a faulty dual scan board do the same.
I'd remove the board temporarily, change it to no adf in service mode and see if the issue remains.
I know it sounds weird but if I haven't seen it myself I'd be skeptical.
5 minute diagnostics;)
tsbservice
10-19-2021, 05:42 PM
Good call I agree after re-examine test page. I would reseat connectors for PH unit but may need new one.
blackcat4866
10-19-2021, 11:56 PM
By all appearances the fault affects all colors, but to be sure, print this:
tsbservice
10-31-2021, 08:07 AM
50439
rrrohan did you find the culprit?
sendpiks
11-09-2021, 05:18 AM
I have similar problem on my BH 452 and solved it when replaced motors, I replaced motor for black drum AND motor for belt, I don't know what motor was the issue but after replacing problem was gone..
