View Full Version : C258 error code C-C164
tulintron
10-20-2021, 07:36 PM
C258 printing USB port, FW G00-W4
Electric discharge caused D011.
After repairing the MFPB board, D011 continued.
I got MFPB from a working C368.
Removed EMMC, 02 Eeprom's, HDD.
Installed EMMC, 02 Eeprom's, C258 HDD
Install FW G00-W4 and after power on, C-C164
part number of identical MFPBs. (A7PUH020)
byronf
10-20-2021, 07:56 PM
Hi,
MFP board procedure gone wrong you need to enter the machine type info before at the beginning of FW also ensure that the original EMMC of the machine is mounted on the board.
Your best bet is to have the board reset and go through the board replacement procedure as per SM.
50497
tulintron
10-20-2021, 07:59 PM
Hi,
50497Machine type successfully entered and exchange procedure agreed with SM.
I've read in other posts that boot firmware is required. I have several base FW. Do these base FWs have the boot file included?
My FW Base starts at G00-16.
tulintron
10-20-2021, 10:12 PM
Some help?
Synthohol
10-20-2021, 10:28 PM
D011 i thought was a HDD issue?
Related Products:bizhub C368,bizhub C258,bizhub C308,MFX-C2590,MFX-C3090,MFX-C3690
Related Options:
Error
CD010, CD011, CD050, CFA14 and/or miscellaneous HDD errors.
Root Cause
Corrupt data.
Workaround/Fix
Install Recovery Tool firmware GXX-A8 or Preventive firmware GXX-B0.
tulintron
10-20-2021, 10:40 PM
Thanks, Synth.
I performed this procedure as well, according to the bulletin, but did not complete the procedure.
I changed HDD, updated FW, performed bulletin step D011, but without success.
We decided to exchange MFPB. Then I come across C164.
tulintron
10-20-2021, 10:48 PM
Related Options:
Error
Root Cause
Corrupt data.
Workaround/Fix
In this procedure, Sata Controller FW has an error and does not update
tsbservice
10-20-2021, 10:52 PM
Try it without and later update it
