View Full Version : Residue right side of prints
positiveg
11-05-2021, 06:56 PM
Hi there guys me again. I don't know if my machine is just having a bad week lol.
What would be causing this? I did change the developer powder thanks
And it's not just on large sheets this is a letter size paper
50715
Sent from my SM-A325M using Tapatalk
tech_in_greybruce1
11-05-2021, 07:06 PM
Look at the fuser rollers then work backwards from there
Quatro
11-05-2021, 07:19 PM
50715
Hi,
I think you have some issue on main charge unit arcing.
lartis.aineias
11-05-2021, 07:33 PM
I believe is the bk drum!
Στάλθηκε από το AC2003 μου χρησιμοποιώντας Tapatalk
Quatro
11-05-2021, 07:50 PM
do you mind to share the model of the machine
Synthohol
11-05-2021, 07:51 PM
Don't take this personally but what I'd like to know is whatever happened to stopping the machine at different points of the copy process and see where the problem develops
If the dots are there before the fuser that eliminates the fuser.
Run a few blank sheets and If the dots are still there I'd look at the transfer belt cleaning.
Pull the belt and see if the dots are on the belt before or after the image.
patrickjlc
11-05-2021, 08:19 PM
What kind of machine is it? Did you check the drum ot transfer belt?
Sent from my motorola one 5G UW using Tapatalk
positiveg
11-06-2021, 03:34 PM
It's a C454. Sorry for not mentioning that earlier. I'll take a look at the drum and transfer belt to see if there's any residue plus stopping the job to see possibly where they may be coming from
Thanks all
copier addict
11-06-2021, 04:29 PM
50715
It looks like a dev unit problem. Did you replace the entire dev unit or just the powder?
Try a brand new dev unit
patrickjlc
11-06-2021, 04:49 PM
You can try printing the paper long ways instead of landscape and see if it shows up. To me it looks more like a drum unit has gone bad. How many prints the machine has?
CopierNerd
11-06-2021, 06:34 PM
I think these spots are on drum unit. Check transfer belt unit.
