View Full Version : Name of itens Minolta
andrecopfac
11-05-2021, 07:04 PM
What is the name of the foams used in the seals of the waste box and cleaning blade ?
blackcat4866
11-05-2021, 07:13 PM
I suppose that I would call them "cleaning unit seals", but depending on the model, they may not be available as individual parts.
What model did you have in mind? =^..^=
andrecopfac
11-05-2021, 07:24 PM
[QUOTE = blackcat4866; 1961910] Suponho que os chamaria de "vedações da unidade de limpeza", mas dependendo do modelo, podem não estar disponíveis como peças individuais.
Qual modelo você tem em mente? = ^ .. ^ = [/ QUOTE]
I would like to know the name of the material, not the part number.
lartis.aineias
11-05-2021, 07:31 PM
I would like to know the name of the material, not the part number.We are technician not chemist [emoji23]
Στάλθηκε από το AC2003 μου χρησιμοποιώντας Tapatalk
Synthohol
11-05-2021, 07:42 PM
Foam pads are foam pads.
you can buy sheets of foam, cut to size and use nito tape or upholstery adhesive spray.
