C550 with error C3424
  • jmandassociates
    • Sep 2008
    • 186
    Need help with a C550 with a C3424 error. I tried a good fuser in the machine and still got the same error. I also tried the fuser from this machine in another C550 and the fuser worked fine in the other machine. Do I need to clear the error somehow or what else should I try next before replacing boards.
  • Leafer999
    Fixing unit reset procedure
    Turn off main power.
    Turn power back on while holding down the utility/counter key.
    The trouble reset will appear. Press it, and wait for it to say ok.
    Turn power off. Wait 10 seconds, and then back on.
    Hope this helps.
    • jmandassociates
      • Sep 2008
      • 186
      Thanks that did it.
