View Full Version : MFC-L861, skewing images...
Oystercopy
11-22-2021, 10:44 PM
Hey guys,
So I've gone out to this machine, and it is skewing (tilting) the image to the right of the page, both on paper tray and Bypass.
I've gone in and cleaned the registration roller (which seemed to have a lot of buildup, for some reason) and still it skews. I believe this to be happening prior to image formation and fuser, so that's why I went for
the reg roller.
Any help appreciated!
OC
blackcat4866
11-22-2021, 11:01 PM
Could this be a Brother MFC L8610CDW, maybe?
I don't seem to be finding references to the model you indicate. =^..^=
blackcat4866
11-22-2021, 11:22 PM
If it is the Brother MFC L8610CDW, did you check to see that the imaging drawer is latched in on both sides? =^..^=
Oystercopy
11-22-2021, 11:25 PM
it IS the 8610 Black Cat, thanks for that!
I didn't see a latch on the right side, only the left (green handle?)
OC
blackcat4866
11-22-2021, 11:42 PM
No, only one green lock lever, down locked, up unlocked.
Also check that both the envelope pressure levers are set to the upper position (plain paper). =^..^=
Oystercopy
11-23-2021, 12:11 AM
Oh, OK! Where are those, on the fuser or something? Or in the paper feed area?
OC
blackcat4866
11-23-2021, 12:30 AM
Two gray levers, opposite sides of the fuser. =^..^=
Oystercopy
11-23-2021, 04:01 AM
Thanks BC, I'll have the customer try that. Although I wonder how this could cause the development of the image to be skewed before the fuser?
I would also think I would have wrinkling too, or am I thinking about that the wrong way?
OC
blackcat4866
11-23-2021, 04:02 PM
I gathered what I did from the Brother online users manual. You could too. =^..^=
tsbservice
11-23-2021, 04:19 PM
Hey OC do you need SM?
If image is tilted that means it happens before fuser so grey envelope levers(normally should be in upper position) are not the cause of this.
I would check for hiden bit of paper in reg section, reмove drum unit a belt unit and check for foreign particles and if they seat evenly level.
Oystercopy
11-23-2021, 06:04 PM
Thanks TSB... yeah, I wondered how the fuser levers would cause this if it's happening before (or during) image formation.
I just talked to the customer this morning, and she's been re-using label sheets, over and over again. I suspect she might have gotten a label stuck in the registration section along the way (somewhere, I can't see it), but
customer does not want to spend a lot on repairs, so I told them the next best option is to replace it with another disposable machine.
OC
