Synaux
11-23-2021, 12:30 AM
Basically, this belt has less than 80k on it and it is leaving a very noticeable mark of thick-glossy stocks (not so noticeable on thick matte and hardly at all on 60lb and thinner). This mark appears to be in line with the pickup rollers (middle of page) and goes edge to edge. It has a grayish appearance but looks to have all the colors.
I am 99% sure its the belt:
Swapped the transfer roller first
I cleaned the hell out of it out of the transfer belt cleaning/waste section, but when turning the belt the skid mark could be easily seen on the belt even after cleaning the felt roller multiple times. What I really do not understand is how the mark is being generated on the belt itself with manual rotation. The waste/cleaning section was nearly spotless. The felt roller is soft and has no evidence of buildup or wear.
Cleaned the belt itself too (was fairly clean).
There is slight wear on the belt where the mark is being created, but I have seen MUCH worse without image degradation. The wear mark couldn't be be detected by a blind man.
Reassembled, and the mark appeared on paper passage test (first print made) with identical appearance.
Background voltage and transfer belt cleaning voltage in SM didn't do anything.
Aside from taking the rear cleaning section apart (a bit of a hassle) I don't know what to do other than replace ($$$).
