View Full Version : HP 4200dtn
AMIGOS; I HAVE HP 4200dtn . HOW CAN I CLEAR THE MANTAINCE CALL , OR PERFORM MANTAINCE WITH OUT CHANGING THE MANTAINCE KIT ?
brotherman27
11-03-2006, 02:18 PM
go under the service menu, type in pin # 11420002, go to maint. count, and set to 0...
Lance
11-04-2006, 04:01 AM
Resetting the maintenance-kit counter (LJ 4200/4300)
After a maintenance kit is installed, the maintenance-kit counter must be reset by using the following
procedure.
1 Turn the printer power off.
2 Hold down the check mark(SELECT button), and then turn on the printer power. Continue holding down the check mark button until
all three printer control-panel lights flash once and then remain on. This might take up to 10
seconds.
3 Press (UP ARROW button) to scroll to NEW MAINTENANCE KIT.
4 Press to reset the maintenance-kit counter.
NOTE Perform this procedure only after a maintenance kit has been installed. Do not use
this procedure to clear the PERFORM PRINTER MAINTENANCE message temporarily.
thanks Dear Friends I Slove The Prob, Thanks For Your Help'
