View Full Version : Is TN321 powder compatible with Konica Minolta C250i
Hello ,
I have excess stock of TNH 321 (C364e) toner, my question is: can I reuse the powder to refill empty C250i toners?
Is the powder quality same ?
such as Konica C250i toner have a counter chip and it will be detected as filled but can the machine use 0 counter toner any way ?
Thank you advance.
Phil B.
12-08-2021, 01:52 PM
Hello ,
Thank you advance.Check the formula specs on the side of the box.
kingarthur
12-08-2021, 03:29 PM
You can check the MSDS sheet
emujo2
12-08-2021, 03:34 PM
I have put 322 into C360I with no ill affects, and I have put 8 series color into a C364. no change in the quality..The only thing you want to avoid is toner with added developer. E
tsbservice
12-08-2021, 05:55 PM
8 series, 4 series all toners have added developer...what you're talking about?
copier tech
12-08-2021, 07:55 PM
Hello ,
Thank you advance.
Yes Konica Minolta seem to use identical toner throughout the office range from as far back as the 3 series to current i series.
As an example I've been decanting old C552 drum unit developer & storing it to top up 4e series developer units when they start depleting.
