View Full Version : Getting an orange-yellowish line on pr1nt (posted on behalf of diwaker)
Synthohol
12-11-2021, 03:27 PM
diwakar 2 Attachment(s)
Getting an orange-yellowish line on print
Hello All !
We are getting a yellow-ish line towards the centre on our 12x18 prints. What can be the cause ? Attached screenshot
Printer: Konica C258
Paper: 12x18 300 GSM Art Card
DPI: 1200
Tray: Bypass
Thank you for your help :-)
Attachment 51062 (https://www.copytechnet.com/forums/attachments/konica-minolta/51062-getting-orange-yellowish-line-print-img1-jpg)Attachment 51063 (https://www.copytechnet.com/forums/attachments/konica-minolta/51063-getting-orange-yellowish-line-print-img2-jpg)
Synthohol
12-11-2021, 03:29 PM
its not a yellow/orange issue. you are missing cyan and or black.
check laser slit glass and DV coverage. could be debris behind a doctor blade on one of the DV units
tsbservice
12-11-2021, 03:31 PM
At max paper weight consumables life is critical. Post them plus are you using compatible toner?
Synthohol
12-12-2021, 12:17 AM
i hope he sees this thread and not just kept the "print" one open in his browser hitting refresh every hour ;)
TEST10
12-12-2021, 03:39 AM
I would check the cyan development unit, it must be rubbish
TEST10
12-12-2021, 03:40 AM
Revisarķa la unidad de revelado cian, debe ser basura
diwakar
12-12-2021, 04:12 AM
Hello All !
DPI: 1200
Tray: Bypass
Thank you very much for reposting :-)
diwakar
12-12-2021, 04:14 AM
Thanks for this, we will try it today, however, we cleaned the whole laser unit. We will check for DV units today
diwakar
12-12-2021, 04:16 AM
We are using compatible toner and recently, the black OPC life was over, so we replaced the chip, and then it worked fine.
diwakar
12-12-2021, 04:17 AM
We will again check the cyan DV and all other DV units today and will post result.
Phil B.
12-12-2021, 05:23 AM
We are using compatible toner and recently, the black OPC life was over, so we replaced the chip, and then it worked fine.Turd party toner is a nono.
The chip might get you some miles but will come back.
Is drum turd party also?
Might have missed it, but what are drum/dev counts?
kingarthur
12-13-2021, 12:56 PM
Have you cleaned the PH unit with the wand, or have you removed it and cleaned it, sometimes using the wand isn't enough, you have to physically remove it and wipe the windows
