View Full Version : Miscellaneous Blocco sia copia che stampe su konica minolta c458
Buongiorno, gentilmente qualcuno puo' aiutarmi, ho una konica minolta c458 spesso la stessa va in blocco sul diplay non compare in evidenza Rubrica, la stessa non stampa e' non posso fare operazioni per la copia , non posso nemmeno accedere al contatote per entrare in modalita assistenza.
In attesa di vostra risposta porgo distinti saluti.
Ciao, running this through google translate doesn't help me a lot, seems your panel doesn't work/response properly - not shure if your MFP does boot properly though or if it hangs at some point.
starts correctly after some time the phonebook entry is not available and the copy function is not possible
tsbservice
12-14-2021, 06:16 PM
Post errors from service mode to begin with.
post errors from service mode to begin with.
i cannot enter service mode
femaster
12-16-2021, 12:55 AM
Try the backdoor. Hold down RESET button while powering on. When Trouble Reset pops up, do not hit the button. Instead, do the usual key sequence to get into service mode from there. This almost always works, even if you can't get in it the normal way.
