View Full Version : error d011 c308
romario
12-16-2021, 09:57 PM
i have this error d011 on my konica c308, i need the files
1. A7PU0Y0-F000-GXX-A8
2. A7PU0Y0-F000-GXX-B0
can someone help me my email is
romarioaparicio2@gmail.com
Synthohol
12-16-2021, 10:06 PM
CD011
(1) Contents
Trouble type
CD011: Hard disk out of specifications mounted
Rank
C
bizhub C368/C308/C258 K TROUBLESHOOTING > 3. TROUBLE CODE
K-94
Trouble detection
condition
A hard disk that falls outside the specifications is connected.
Trouble isolation
Relevant electrical parts
• Hard disk (A) (HDD (A))
• Hard disk (B) (HDD (B): HD-524)
(2) Procedure
1. Check the hard disk specifications.
2. Replace the hard disk. (HDD (A) / HDD (B))
firmware likely wont do anything.
is it the original HDD?
if replaced, was it the same size/type?
did you replace the SATA cable as well?
did you try formatting it?
just asking because you did not provide what you have done so far.
romario
12-16-2021, 10:16 PM
CD011
(1) Contents
Trouble type
Rank
C
K-94
Trouble detection
condition
Trouble isolation
(2) Procedure
sorry, if I change hdd 3 times, sata cable, update firmware A7PU0Y0-F000-GXX-B6 and follow the error, read here in the forum that with those files I solve the problem
https://www.copytechnet.com/forums/image/png;base64,iVBORw0KGgoAAAANSUhEUgAAABQAAAAUCAQAAAA ngNWGAAAA/0lEQVR4AYXNMSiEcRyA4cfmGHQbCZIipkuxnJgMStlMNmeyD2d wmc8 sZgxYJd9ErIZFHUyYYD7fkr6l4/rnvmtl7 KitrqV/fq2Y5eLY3Z9S48eRLe7BmVZ9qhTLhQ0algzZWQOVKSsCF8OjAn wbxDTWFDUhPK/jMr1H6HE/IqRky2DyvCefuwItwZzodVoYRiLqMkVCXrwpJ9twZ sgfDYEFYl8wIWxZ9uFf7zkallxlJh4YrLGsKjZRx7VGHhLqwgF UN45DGdb8MeXGpgB4ABZdeDcpZEY51A hyLKz4S1W4MQWm3AibWtgWmk6dyISa1pSdyWTOlLXVp0 eL9D/ZPfBTNanAAAAAElFTkSuQmCC
