View Full Version : bizhub c308 error D011
romario
12-17-2021, 02:26 PM
Someone who can help me with firmware file 1. A7pu0y0-f000-gxx-a8
2. A7pu0y0-f000-gxx-b0
start solving error d011, already change hdd, sata cable and continue with the problem
femaster
12-17-2021, 09:30 PM
Is the hard drive the correct size (capacity) for the copier? See error info below. I've also attached a PDF for Konica's troubleshooting procedure. Hopefully you can read English without pushing it through a translator, or the PDF might not be much help to you...
K.3.25.6. CD011 (bizhub C658/C558/C458/C368/C308/C258)
Contents
Trouble type
CD011: Hard disk out of specifications mounted
Rank
C
Trouble detection condition
A hard disk that falls outside the specifications is connected.
Trouble isolation
Relevant electrical parts
Hard disk (A) (HDD (A))
Hard disk (B) (HDD (B): HD-524)
Procedure
Check the hard disk specifications.
Replace the hard disk.
51147
Synthohol
12-17-2021, 09:50 PM
pm sent.
