View Full Version : Can i set "local" users to print/copy in C458 with AD autentication
danifuenca
12-23-2021, 04:47 PM
Hi, my client want set user account in mfp to print/copy for temporary user which has personal laptop to work without join it to domain server. Is posible set mixed config to mfp?
When i tried set user account in mfp the "edit" button is greied.
Bizhub c458 with G00-X4 firmware and 4.2 function version set. External server is Windows server 2012 and Single Sing-on configured to users in active directory
J_Arnold
12-23-2021, 06:15 PM
I am speaking about a machine I am not certified on, I would assume you could just add a local driver pointing directly to the IP address of the copier, that might work.
danifuenca
12-23-2021, 06:32 PM
But i need create users in mfp to print because autentication is set to on
J_Arnold
12-23-2021, 06:42 PM
Apologies then, I am out of my element. I would assume local printing would bypass user accounts. I know it does on Toshiba devices but again not certified so I would be speaking out of my backside on this product. I thought I could solve the issue without knowledge of the product. Try turning authentication off and see if you can add account, then turn it back on??? I won't be commenting on this anymore since I would be wasting your time.
Best to get with there IT they can setup an account for that user or setup a guest account in AD
J_Arnold
12-23-2021, 06:49 PM
Best to get with there IT they can setup an account for that user or setup a guest account Geez, I overlooked the obvious.
danifuenca
12-23-2021, 06:53 PM
No problem. any help is welcome. In KM when you turn on/off authentication any account created before is eliminated
J_Arnold
12-23-2021, 06:56 PM
Ouch...that is no fun.
danifuenca
12-23-2021, 06:58 PM
I thought that when you configure "MFP + External Server" in authentication method it would allow you to create users on the machine for those temporary users
rrrohan
12-25-2021, 01:25 AM
Or allow public user
Sent from my Pixel 4 XL using Tapatalk
emujo2
12-27-2021, 02:25 PM
This is an excellent point..it would give you the ability to create non domain users (guests). This only drawback is anyone that can learn these codes can now print, and any paper trail only show that the guest user did the printing/scanning. E
