View Full Version : KM C8000 stuck on start-up
supersean9
01-05-2022, 03:11 PM
My KM8000 is stuck on the boot screen "Please wait, starting system"
Any ideas???
Phil B.
01-05-2022, 07:23 PM
Any ideas???HDD .. firmware... defective part.
Can you give is the error code ( if any )
supersean9
01-05-2022, 07:44 PM
There is no code, won't boot that far. Will not allow access to diagnostics either. Just stuck on system starting screen. Tried resetting cables to HDD's, no change.
wjurls
01-05-2022, 08:22 PM
This typically happens when it can't find the HDD or NVRAM. Just hangs up and doesn't know what to do.
Phil B.
There is no code, won't boot that far. Will not allow access to diagnostics either. Just stuck on system starting screen. Tried resetting cables to HDD's, no change.Being an end user do you even know how to find that information?
Cables? NO! Try to format the drive if it fails replace HDD.
lucky13
01-07-2022, 12:51 AM
just so were clear is it the C8000 printer control panel with bad boot screen or is it the Fiery print controller /command work station big silver box not booting
asking for a friend ?
tulintron
01-07-2022, 03:16 PM
Any ideas???Model C7000 has a procedure to rename a firmware and turn on the printer with usb connected. The printer already starts the firmware update and solves this initialization problem.
Model C8000 same year and same schedule. I believe it is the same procedure. Search on and you should find the solution
supersean9
07-11-2022, 04:10 PM
Update, the fix to this was resetting the HDD connections on the main board. Thank you, Sean
