View Full Version : C253 Black Copies and Print Outs
KMNewbie
12-23-2008, 01:41 AM
I have a brand new C253 with about 800 copies on it and all copies or print outs come out jet black with the image in the background......KM is lost in a closet, no help what so ever, so has anyone seen this.....(PRCB, HV Board and Image Processor has been swapped with new boards per KM instruction) Also, is there any tricks to reading bias, grid voltages, etc.... on this model ?
ck1
12-23-2008, 03:30 AM
me got one C250 also got this problem . i will try change the black IU and see. let you konw A.S.A.P
KMNewbie
12-23-2008, 03:43 AM
Tried a couple of different new drums also, still no-go......Thanks for your help !
B0265
12-23-2008, 07:54 AM
Try swapping the Black laser unit with one of the others.
copytechman
12-23-2008, 12:38 PM
I agree, try the print head swap, but also check to make sure the top of the drum/image unit is touching/connecting to the frame solidly, flaky grounds can produce a similar symtom as well.. I know you've changed an iu or 2 but also check the others for arcing @ the rear side contacts.. had it happen as well.
Regards!
A.
Benedict
01-08-2009, 08:53 AM
Hi guy
Had a similar problem did everything under sun but after lengthy investigation found machine slightly bent on the left hand side maybe just something to take a look and look closely.
ni311
01-08-2009, 03:51 PM
You can see the voltages in the service mode.
Is the black background on non-printable area also?
