View Full Version : KM bizhub C458e 32-05 jam
tsbservice
01-24-2022, 02:01 PM
This is remote site so they called today about jamming issue. Machine count is arround 700k all consumables are well within their life recomendations.
It started recently, I logged via remote panel and there are a lot of 32-05 jam codes. I read about faulty/worn loop sensor actuator. Anyone having experience with this model?
What can I bring with me as this is the only one machine of this model we have in field and site is far off.
TIA
blackcat4866
01-24-2022, 02:33 PM
I'd start with PS3, or possibly a seizing fuser. =^..^=
kingarthur
01-24-2022, 04:40 PM
It could even be something as simple as damp paper
mike_hartung
01-24-2022, 04:59 PM
Most likely exit clutch. CL8. I have seen this clutch fail with as little as 400K. J32-02 and J32-05 jams. Plus there was a bulletin on it for the 4 series. I assume they got it right for the 8 series but maybe not. Its about a 2-3 hour job to replace it.
tsbservice
01-24-2022, 05:17 PM
Thanks guys will bring exit sensor and CL8 along with loop sensor spring and actuator.
Had guide from fellow techs here on CL8 replacement with lots of shortcuts. However I noticed it recorded 32-05 jam only from tray 1 while they claimed were doing cross sorting (A4/A4R), may be tray related we will see.
copier tech
01-24-2022, 06:44 PM
+1 on this. A quick phone call to the client ask them to try a new unopened packet of paper is worth a try before you attend.
Bulletin is for the 4e series but I guess the same applies with the 8 series.
51638
