View Full Version : Jamming KM BH4050
scanmc
01-25-2022, 07:27 PM
I have never sold or worked on one of these as this is a new customer that called for a jam code 242.01 and no paper is present. I ran a piece of mylar up through the front paper path right above the first cassette but and all seems clear so I assuming its one of the sensors. I'm logged on to the Konica's One Stop for the service manual but its not listed under documents for either the 4020 or the 4050 series? If someone has the manual they could email me or direct me to the page on the KM site that would be appreciated.
tsbservice
01-25-2022, 08:22 PM
I can provide manual first thing morning. How many trays it has. This is not KM but Lexmark engine most KM techs hate them including me but they can be dogs.
Synthohol
01-25-2022, 10:04 PM
PM sent.
242.01
Paper over tray 2 Pass through sensor on warmup
Restart the printer.
Does it fail to complete the POST sequence and
display a 242.01 error?
Replace the option tray.
Go to step 2.
2
• Enter the Service Mode and perform a paper
passage test:
Select [Service Mode] -> [State Confirmation] ->
[Paper Passage Test] -> [Tray 2], and touch Start
key.
• Cancel the test after five pages.
Does the printer successfully feed the five pages into
the output bin?
The problem is solved.
Go to step 3.
3
Does the printer display a 242.06 error?
Replace the ACM assembly.
Go to step 4.
4
Check the pick roller assembly.
Is it free of wear or damage?
Go to step 5.
Replace the pick roller assembly.
5
Check the separator roll assembly.
Go to step 6.
Replace the separator roll assembly.
6
Check the tray guides, lift plate, and lift plate gears.
Are they free of wear or damage?
Go to step 7.
Replace the tray insert.
7
Check the ACM assembly.
Go to step 8.
8
Enter the Service Mode and perform a paper passage
test:
[Paper Passage Test] -> [Tray 2], and touch Start key.
Does the pick/lift motor gearbox pass the test?
Go to step 9.
9
Does the error remain?
Contact the next level of support.
• Link to the wiring diagram (N.1. bizhub 4750/4050)
I can't recall specific any details but one time I had a prob with an actuator and several other times I needed to install the modified (green) feed rollers.
