View Full Version : km c654e
romario
01-27-2022, 09:50 PM
hello group. I have this error in printing, the first impression fails, and the second one goes well, now I cause a paper jam before the machine makes the transfer to the paper and the impression is perfect in the ibt, the fault is when transferring to the paper. I already changed the transfer roller and the fault continues,
5168751688
https://www.copytechnet.com/forums/image/png;base64,iVBORw0KGgoAAAANSUhEUgAAABQAAAAUCAQAAAA ngNWGAAAA/0lEQVR4AYXNMSiEcRyA4cfmGHQbCZIipkuxnJgMStlMNmeyD2d wmc8 sZgxYJd9ErIZFHUyYYD7fkr6l4/rnvmtl7 KitrqV/fq2Y5eLY3Z9S48eRLe7BmVZ9qhTLhQ0algzZWQOVKSsCF8OjAn wbxDTWFDUhPK/jMr1H6HE/IqRky2DyvCefuwItwZzodVoYRiLqMkVCXrwpJ9twZ sgfDYEFYl8wIWxZ9uFf7zkallxlJh4YrLGsKjZRx7VGHhLqwgF UN45DGdb8MeXGpgB4ABZdeDcpZEY51A hyLKz4S1W4MQWm3AibWtgWmk6dyISa1pSdyWTOlLXVp0 eL9D/ZPfBTNanAAAAAElFTkSuQmCC
tsbservice
01-27-2022, 09:56 PM
Change paper size is it the same. Looks like brush effect try to fine adjust fusing speed in SM.
romario
01-27-2022, 10:03 PM
A3 /SRA3 same fault. now the missing toner on the paper. it is in the ibt band, it seems that it did not cover 100% of the toner
a..
romario
01-27-2022, 10:05 PM
blackcat4866
01-27-2022, 11:11 PM
What media type?
Have you selected the correct media type setting?
copyman
01-27-2022, 11:59 PM
Once again a lot of important information is missing, What is total page count? Transfer belt life count? Using genuine toner & other consumables?
Almost looks like the transfer belt when you wipe it down with alcohol and it take several pages to clear up. I would focus on the Trans belt.
romario
01-28-2022, 12:23 AM
I already changed ibt module. original toner. occate the paper lock before transferring to the paper to verify if the image came from the ibt band defective. but it is not perfect 100%
