View Full Version : C750i bypass & 300g paper
suomi
01-28-2022, 10:44 AM
C750i & 300g paper does not work at all. New machine. Other papers will work.
Tested same paper old C258 & C558 works fine.
Any ideas??
what do you mean? no feed? fuser issues?
suomi
01-28-2022, 11:21 AM
J10-01
if you push the paper by hand then it works
J10-01
Ah OK, I recall that you can swap the feed roller rubber with a different one from a production machine to increase the "grip level" - onother hint I got is using the sep roller stuff from older series. I can try and figure out wich customer it was, perhaps I'll find some parts infos.
Edit: 4034015101 (sep roller) / Feed roller mod is not necessary according to my guys
