View Full Version : Miscellaneous Gray line on Bizhub C7000
ANIP87
02-02-2022, 12:51 PM
Hi all please help me.
I have a problem on bizhub c7000. The problem is gray line.
I already check drum unit, dev unit, charging, transfer bel unit, writing unit but the problem still there.
Any solution please...
lartis.aineias
02-02-2022, 12:53 PM
Any solution please...Try first to change the fiery cable!
An 2nd i believe image control board
Στάλθηκε από το AC2003 μου χρησιμοποιώντας Tapatalk
Toxic
02-02-2022, 01:33 PM
If you output test prints from service mode is problem still there?
ANIP87
02-02-2022, 02:51 PM
Already change the fiery cable still problem. The gray line is there both from file and test pattern.
ANIP87
02-02-2022, 02:54 PM
Yes it is. i already take test pattern 58,53 & etc.
If any black color will be any grey line sir.
Phil B.
02-03-2022, 08:11 PM
Any solution please...How did you 'check' those items?
My guess is drum unit or cleaning assm.
Phil B.
02-03-2022, 08:12 PM
Replace K drum.
lartis.aineias
02-03-2022, 09:03 PM
I see a digital problem.
2 years ago I had about the same problem, after changing drum, laser, I changed the board and the problem was fixed.
MCB1 board
ANIP87
02-04-2022, 05:00 AM
Drum unit and Developing already change.
Cleaning belt had changed. +6281385267300 (whatsapp or telegram)
ANIP87
02-04-2022, 05:08 AM
MCB1 board
Many thanks. I have chnged mcb1 on july 2021, because of errors E006.
