View Full Version : C360i
rrrohan
02-07-2022, 03:41 AM
Stuck on 2 codes on a C360i where it would lock up completely
first it was C40C5: CTL PF transmission timeout 2
So I changed the CPU board. same error so i changed the sub board (MFPB)
At first I thought it was ok but few days later got reports of issues again.
Needs the SSD update as its on G01-01 but it gets to screen to update but no start button to begin and leaving it untouched for 15 mins doesn't start it neither.
I know the symptoms of the old SSD firmware aren't the same as im experiencing but the fact it wont take update makes me think that there is a fault and that it may be causing the lockups im seeing.
Should I order a replacement storage board AA2JM72702
tech51
02-07-2022, 05:56 PM
The ssd update is only for the phison storage boards.
If a different storage board is fitted it goes through the whole firmware process but doesn’t display a start button.
I got caught out on this one on some c450i machines I have in the field until I read the readme file properly😉
I would suspect the update is not required on this machine.
What issues are you getting with it and does it take the main firmware ok?
tsbservice
02-07-2022, 06:03 PM
I only update SSD firmware on this series when Storage controller firmware is AA2J0Y0-6501-G01-07.
Easy to check via web interface or in CE mode. Never attempted on other types of SSD as it's not for them.
tech51
02-07-2022, 06:15 PM
It doesn’t do any harm if it’s done on non phison boards. As I said above it won’t display a start button so nothing gets updated.
tsbservice
02-07-2022, 07:05 PM
Alas they did it right but I don't bother waiting for it while quick check reveals if SSD update is worth.
tech51
02-07-2022, 09:48 PM
Yes I do the same but I just mentioned it in case people were concerned it indicated a fault or damaged the machine which, just to clarify, it doesn’t.
rrrohan
02-08-2022, 12:55 AM
it was on G01-02 which is older than G01-07 so i thought it needed it. maybe not.
yeah it takes normal firmware ok
Just locks up after a print job and even though print job finishes the screen freezes
also only way i can get into service mode in via trouble reset, if i go the normal way it locks up the second i click in after typing CE code
Albonline
02-08-2022, 02:52 PM
did you run the self diagnostic mode? I've seen this before and it turned out to be the base board.
rrrohan
02-09-2022, 12:37 AM
already put a new base board in and CPU board.
ive ordered a new SSD to try
Woxner
02-09-2022, 01:29 AM
Have you tried reformatting the hdd. Fixes a lot of issues. It may not be bad.
rrrohan
02-09-2022, 02:11 AM
I don't think it has a HDD from memory
Sent from my Pixel 4 XL using Tapatalk
Woxner
02-09-2022, 02:26 AM
Its attached to the cpu also known as memory. Everone gives it a different name. Acts as a hdd
rrrohan
02-10-2022, 12:49 AM
oh the NVME drive, yeah i wasnt aware you could format them. if thats the case i could of taken one from one of the many DOA (drunk forklift driver i assume lol) C360i I have? i ordered a new one thinking it was like the other boards where you can use 2nd hand parts
