View Full Version : Miscellaneous IO checking bizhub C7000
ANIP87
02-09-2022, 02:45 PM
I did io/ckecking 98-09 with result "NG".
Can help me fix/repair it. Please
Phil B.
02-13-2022, 04:59 PM
Can help me fix/repair it. PleaseMight want to locate A service manual.
Synthohol
02-13-2022, 08:22 PM
Image processing board
line memory (SDRAM) /K
check
5.7.10 Printer image processing board line memory check
(1) Usage
When the image of a particular color is misaligned in the sub scan direction and a notable image trouble occurs, check whether there is any
abnormality on the line memory of the printer image processing board (PRIPB).
(2) Procedure
1. Enter the I/O check mode.
2. Enter "98" with the numeric keys.
Confirm that "98-00" is displayed on the message display area.
3. Press the Access key.
4. Enter one of the followings with the numeric keys.
Check that "98-##" (## represent multi-code number) is displayed in the message display area.
Multi-Code 06: Printer image processing board line memory (SDRAM) check /Y
Multi-Code 07: Printer image processing board line memory (SDRAM) check /M
Multi-Code 08: Printer image processing board line memory (SDRAM) check /C
Multi-Code 09: Printer image processing board line memory (SDRAM) check /K
5. Press the Start key.
During the operation-"NOW" is displayed
The operation succeeded - "OK" is displayed
The operation failed - "NG" is displayed
When "NG" is displayed, replace PRIPB.
A1DUH06011
Image Processing Board /P Assy
