View Full Version : KM paper size sensor VR1 adjustment
sunsetoutpost
02-18-2022, 08:46 PM
You guys are pretty smart, someone has to have figured this out. How can I set (fudge) the meshing of the VR1 gear so it registers the correct paper size? I've already had the drawer apart twice (remove lift motor, wires and lift plate) in order to get to the darn thing. Why doesn't the SM give a resistance measurement for a specific paper size so I can just take this apart once?
tsbservice
02-18-2022, 08:50 PM
And machine model is?
sunsetoutpost
02-18-2022, 09:05 PM
DI850
sunsetoutpost
02-18-2022, 09:47 PM
Swapped VR1 with another machine, same result. Going to look deeper.
Flash
02-18-2022, 10:07 PM
It has been a while since I have worked on a crusty old Di850 but there should be a tray size adjustment in the service mode.
blackcat4866
02-18-2022, 11:52 PM
Most other KMs have a calibration in service mode. I don't know for sure about the DI850. =^..^=
Synthohol
02-19-2022, 12:47 AM
n
1
Enter th
e 36 mode.
2
[Adjust
Press "
ment mode menu Screen]
Image adjustment".
3
[Image
Select "
adjustment mode menu Screen]
Tray adjustment".
4
[Tray a
Press th
select t
The scr
1 (2) to
to Tray
Using a
(the inn
plates o
and to 2
Set the
faces of
pass tra
280 mm
djustment Screen]
e or key to
he tray to be adjusted.
een changes from Tray 1 (1) to Tray
Tray 2 (1) to Tray 2 (2) to Tray 3 (1)
3 (2) to By-pass 1 to By-pass 2.
scale, set the distance between
er surface of) the paper side guide
f each tray to 250 mm on Tray (1),
80 mm (8.5x11) on Tray (2).
distance between (the inner sur
) the paper side guide plates of by
y 1 to 210 mm (A4R) and tray 2 to
(8.5 x 11) respectively.
5
Press t
The sel
adjuste
After ad
displaye
he key.
ected tray is automatically
d.
justment completes, a message is
d.
6
Press t
he key
sunsetoutpost
02-19-2022, 03:13 PM
[QUOTE=Synthohol;2104233]
n
1
Enter th
e 36 mode.
2
[Adjust
Press "
Image adjustment".
3
[Image
Select "
Tray adjustment".
4
[Tray a
Press th
select t
The scr
1 (2) to
to Tray
Using a
(the inn
plates o
and to 2
Set the
faces of
pass tra
280 mm
djustment Screen]
e or key to
5
Press t
The sel
adjuste
After ad
displaye
he key.
d.
d.
6
Press t
he key
Awesome, I'll give 'er a try
sunsetoutpost
02-21-2022, 03:15 PM
All good now, don't know how I missed that in the SM. Guess that's one that I hadn't run into before. Thanks to all
