blazebusiness
02-20-2022, 05:35 PM
Wondering if anyone has seen this error before. I have yet to go out but will go out and try a FW update for starters. Problem:
Code FB-08 code. Konica Bizhub 4050
From the manual : Abort code,
ABORT CODE
4.1 Troubleshooting of the abort code
• The machine displays an abort code (F###) on the operation panel as it becomes unable to process tasks properly through its software
control.
• When the system program is aborted, check the electrical component, unit, option, and connection relating to the specific type of the abort
FB-08 error: Asahi ASIC error (IMAGE)
Memory error: ASAHI register setting error Possible bad controller board (CTLB)
Customer has documented the following recent error history:
The first trouble code was on 1/25 after I made a 1 page copy through the feeder -the error code was FB08(000.00)
4 hours later I made a 1 page scan through the feeder – the error code was E301(000.00)
Next was on 1/27 after I made a ½ sheet copy through the feeder -the error code was FB08(000.00)
4th time was on 2/10 -I came into work to see it displaying error code E301(000.00)
Just now on 2/18 it randomly displayed error code E301(000.00)
ABORT CODE
control.
