View Full Version : Swap Battery from MFPB Board on bizhub C-224e Series
CP-1015
02-24-2022, 12:41 PM
How to change the battery on the MFPB board without junk? Can the battery be removed after disconnecting the SSD? Thans advanced.
wjurls
02-24-2022, 04:55 PM
It's been suggested somewhere on this site before to solder a new battery in parallel with the old one first, then cut the old battery out of the circuit.
This is a good strategy to avoid wiping out the memory.
CP-1015
02-25-2022, 05:54 AM
Thank you!
Yes absolutely bypass the old battery with a new one before cutting it off so the MFP board is provided with battery voltage at all time. Are you perform this as a precaution?
CP-1015
02-25-2022, 07:50 AM
Yes, for batteries with 3 or less volts voltage.
Good thinking - we also have a look if the MFP is considered not to be swapped in a foreseeable timespan.
There's a lot of refurbished Cxx4e out there, it's important to check them because we weren't aware about this at the time of refurb&reselling.
CP-1015
02-25-2022, 04:25 PM
It would be interested to know from which memory the data is lost, because the SSD and memory board/1 can be safely unplugged. After all, it is a PC motherboard.
