View Full Version : KM-4035
LNorris
01-02-2009, 09:42 PM
see if you guys have had this one before :)
i went to work on this june 2008. it is a rental so its been replaced and i've just now gotten some down time to work on it.
when i went to work on it last year, it had a code 3100 (scanner carriage), after t/sing the thing, then it flipped a fuser code, 163 wouldnt clear it and put a new fuser in it...the machine died after a 4200 code .
so, i've put a new lsu in it..comes up fine...make about 150 copies, the machine starts to reboot itself in the middle of copies, just power off and on...continuously. i get a firmware update into it..and it still does it...any ideas on this one? Kyocera tech support off today.
Jimbo1
01-03-2009, 05:29 PM
The main charge isn't arcing is it? That might give you some rebooting.
vikingmita
01-05-2009, 10:25 PM
-and explain 4200. change charge or worst case whole drum unit.
LNorris
01-05-2009, 10:36 PM
4200 is LSU/polygon motor issue.
seems the 24v is dropping when this occurs, i have a tech rep here helping me t/s this. he thinks there is something wrong in the power supply. i'll let you know what we find out.
Jimbo1
01-05-2009, 10:52 PM
If his last name is General he will probably find it.
He's a good man, that guy!
LNorris
01-05-2009, 11:34 PM
that would be him! he is down here setting up our new TaskAlfa as well
vikingmita
01-06-2009, 08:26 AM
<4200 is LSU/polygon motor issue.
yep, but arcing of high voltage from unclean charge/bad drum unit will quite often give you same error msg. on the falcon-series. had tens of those faults. best case: clean charge, worst case: change whole drum unit. have not had one bad lsu ever on those machines
nnnggg
05-11-2009, 04:20 PM
C4200
my case to chang charge block
bdove
05-28-2009, 04:22 AM
Dont know if you have fixed this problem yet but the main charge needs to be replaced on the machine. If the drum is pitted then replace drum and charge and your problem will go away.
QUOTE=LNorris;54409]see if you guys have had this one before :)
so, i've put a new lsu in it..comes up fine...make about 150 copies, the machine starts to reboot itself in the middle of copies, just power off and on...continuously. i get a firmware update into it..and it still does it...any ideas on this one? Kyocera tech support off today.[/QUOTE]
