View Full Version : TN613 use on C452 copier
jwai
03-03-2022, 03:34 PM
Hello,
Due to global supply issue, TN413 are out of stock, only have TN613 toner at warehouse.
They would be used on C452 copier? Thank you.
kingarthur
03-03-2022, 04:27 PM
as far as I can remember they both use the same developer, so I guess the toner must be compatible, I think you just need to change the end cap
Mr Broots
03-11-2022, 03:57 AM
Yes, for sure. Just swap the caps of break the fins on the 613 cap. You'll need a chip, or if you swap caps it will just read low but won't stop the machine. You can also use 711, 712, 618, 713 although it's a bit more involved because you have to swap the rear indexer, since the 711, 618, 712, 713 are all different
