View Full Version : Bizhub 808 - C-FA 14
Hello~
Tried unsetting HDD (waiting on a new HDD), resetting code several times, replaced main board and newest firmware. Machine still won't clear the code. Anyone had this?
Thank you in advance.
tsbservice
03-07-2022, 07:37 PM
Did you disconnect HDD together with disabling it?
Synthohol
03-07-2022, 10:51 PM
Problem
When PaperCut is installed with U8 or higher firmware the following issues may occur.
CFA14 error code
Card Reader is unable to authenticate
The PaperCut Application is removed from the device since the IWS on the device crashes
Http Transport error reported on PaperCuts Log.
Solution
CAUSE: Firmware requires updating.
SOLUTION: Install the following firmware version depending on MFP.
bizhub 808/958 - A7950Y0 - F000 - GG7-W5
Problem
Insufficient Memory message, also CE301 or CFA14 error codes.
Solution
CAUSE: Problem causing CE301 by operation of screen transition of browser application. Problem with CFA14 caused by repeated operation of launching OpenAPI application / MFP standard function(copy etc) from IWS application
SOLUTION: Some Special firmwares are available: GG1-R9 should resolve both these error codes.
If CFA14 is not resolved then update to GG6-R9 which is available for most models in this series, should be available for the other machines by end of March 2018 .
C-FA14 or C-D**
Connection failure of HDD
HDD failure
thats all i got.
