Mr. Breaker
03-12-2022, 05:46 PM
Hi,
This week we had an interesting case with a Konica Minolta Bizhub C550i (machine with memoryboard)...
The customer compliant about color copies, as there was an dotted pattern as background to the image.
When outputting the “testpage” (the one with the bird), only K is doing the correct gradation pattern but all colors (so C,M & Y) don’t do any gradation. So any RGB gradation pattern is 100%, so the 5% gradation check area has an solid 100% coverage and the photo of the bird is (almost) solid black.
Machine was on firmware version AA7N0Y0-F000-G00-K8-970.
We changed the baseboard, but the problem was persistent.
To make a long story short… It turned out to be an simple fix. Just alter the “function version” (softswitch 25) of the machine and change it to any existing function version and after the alteration, change it (back) to the appropriate version (in our case hex 30, so v2.2) and the problem is solved. This problem can probably also happen on the C450i and 650i (or maybe even C250i, C300i or C360i, not sure though about this slower series…)
As you can imagine it was quite “an ride” to find the solution… So I post it here so you guys won’t have to invent the wheel and make a lot of expenses on parts and boards that aren’t the solution. For reverence I added the abnormal “testpage” output of the machine.
52500
Best regards,
Mr. Breaker
52500
Best regards,
Mr. Breaker
