View Full Version : Bizhub C-458 A79J0Y0-F000-GC5-X8
CP-1015
03-14-2022, 11:39 AM
Above machine shows at MFP Card Version:
2,ID=000000,NM=000000,OP=0S. Is it correct? Thanks advanced.
tsbservice
03-14-2022, 02:58 PM
Should last on ..... GC5-X8
What's the problem?
CP-1015
03-14-2022, 04:41 PM
What's the problem?
I've never seen that: 2,ID=000000,NM=000000,OP=0S. And it's not possible to read unitstatus per SNMP - only toner and wast toner box.
tsbservice
03-14-2022, 05:28 PM
... And it's not possible to read unitstatus per SNMP - only toner and wast toner box.
soft switches 227 and 230 set them to 00...good luck
Synthohol
03-14-2022, 05:29 PM
Hit utility and device information. Scroll down for the fw version installed.
CP-1015
03-14-2022, 05:46 PM
There it's the same:
tsbservice
03-14-2022, 05:47 PM
As a bonus you can see also function version. Since I started on KMs few years ago I rarely ever check FW versions in CE mode.
Maybe only on older models or when machine behaves erratically.
CP-1015
03-15-2022, 07:46 AM
Thank you! After switch 230 to 00 function as usually.
But what's the meaning of "2,ID=000000,NM=000000,OP=0Sum"?
