New to Lexmark
  • Shadow1
    • Sep 2008
    • 1642
    New to Lexmark
    I just inherited about 200 Lexmark T632 and T642 printers, and have never worked on them before. I've been working on HP Printers, Toshiba, Sharp, and Ricoh copiers for over 10 years, so I'm pretty handy with a screwdriver just not familiar with these products.
    I ordered the service CD and a PM kit for each model. What else do I need to know to keep from driving myself nuts?
    73 DE W5SSJ
  • prntrfxr
    • 1627
    New to Lexmark
    Remember when your troubleshooting that Lexmark does not put the charge roller in the cartridge. You can see it when you almost close the toner door in the upper part of the toner cavity. If you get black pages and its dirty you can clean it with alcohol. If its defective you'll need to replace it and when you take it out make sure the brass bushing doesnt fall out of it.
    Some of the earlier lexmarks had ciruit boards on the fuser instead of in the machine like hp does. Although I think the ones you're working on have it in the printer instead.
    The transfer rollers go in the reverse direction from HP.
    Ive had scanner error which turned out to be a defective fan (laser scanners have the exhaust fan cables tied together but not connected to each other). Fuser errors from a broken fuser connector tab on the connector the fuser connector plugs into.
    The system boards and engine boards are built in together which makes troubleshooting easy, but is an expensive part.
    Lexmark uses the engine type number on the label with the serial number instead of the model number on the front of the machine. This number is real important when ordering electronic parts and occasionally important when ordering non-electronic parts.
    For example the T640/642/644 has the following engine types:
    4061-000 T640
    4061-010 T640n
    4061-200 T642
    4061-210 T642n
    4061-400 T644
    4061-410 T644n
    I hope that helped you some.
    Life should NOT be a journey to the grave with the intention of arriving safely in an attractive and well-preserved body, but rather to skid in sideways - Coke in one hand - chocolate in the other - body thoroughly used up, totally worn out and screaming "WOO-HOO, what a ride!".
    • Shadow1
      • Sep 2008
      • 1642
      Thanx - My sanity may be at stake here. I was already overworked and underpaid before they dumped 200 unfamiliar printers on my head - the only information / instructions I got were "this is a half million dollar account, the IT department doesn't want us here, don't screw up"
      73 DE W5SSJ
