View Full Version : C250 + FS-514
B0265
01-07-2009, 10:36 AM
Have any of you guys installed a FS-514 on a C250?
I have changed the connector and tried with several FW versions from H5 or later.
The machine hangs in "warming up" when the finisher is connected. The Finisher works fine on a C252.
kiwitechnician
01-07-2009, 10:52 AM
1.Does machine work fine without finisher ?
2.If you connect finisher is there any error message ?
B0265
01-07-2009, 12:15 PM
1. Yes
2. No error message, but the display shows "warming up" and the Copy key stays orange.
Two strange things:
- If I look at the FW versions i service mode, the finisher fw is shown as "9J08-0090-06-00-(" (no check sum)
- If I try to upgrade the FS-514 FW when it is connected to the C250, I get the message "Not connected" after a while.
kiwitechnician
01-08-2009, 06:40 AM
I would check all connections between FS and engine, it looks like engine has loose connetions or bent pin. If I ever have had any similar issue for example between scanner and machine, there were the same indicators like corrupted fw, orange start button.
