View Full Version : Konica biz hub 363 can’t scan to external memory stick
DOE
04-08-2022, 02:35 AM
When I insert memory stick screen says it recognizes it but function is unavailable. I turned on scan to external memory in the admin. Mode but it still says function not available. I have done same thing on color copiers and it always worked. Is there something else I need to do on the 363 to make scanning to external memory available.
emujo2
04-08-2022, 03:16 PM
There are usually 3 culprits
1. Feature is disabled in Admin Mode
2. Feature is disabled in User Authentication/Account track
3. USB device issue..
Some other areas..Possibly a HDD is needed (363 came with one but may be removed or disabled)
Security Settings - Quick Security Setting - USB Enable Settings Check to see if USB is disabled here
Hansoon
04-08-2022, 03:21 PM
+1
Without it scanning to USB will not function
Hans
cyta123
04-09-2022, 09:49 PM
It is one of the symptoms ssd failed. Soon after that you are not availble log in machine via www.
Format ssd, then reset network card - if you can't find procedure to fix ssd, let me know I will send you pm.
You don't need hdd.
DOE
04-13-2022, 04:56 PM
You don't need hdd.
Can you please send me that info. Thank you.
cyta123
04-21-2022, 10:09 PM
53068
