View Full Version : Firmware upgrade on production press
reckless
04-27-2022, 06:01 PM
Do you need to upgrade firmware in order from 1 to 2, 2 to 3.... latest version. I remember older KMs had this requirement esp for fiery firmwares. I have the latest firmware for KM C6100. I don't believe any upgrades have been done since 2019. Can I just flash it with latest?
wjurls
05-06-2022, 07:03 PM
It isn't always necessary. Some firmware updates will require you to launch from a specific prior version, but most don't. Read the firmware info .pdf that accompanies the latest version carefully so see if a prerequisite step is required. Particularly if using a "special" firmware and not a mass release version.
wjurls
05-06-2022, 07:18 PM
I forgot to mention. If there is a huge disparity between the current version and whats on the machine (i.e. Machine is at level 20 and the latest is level 60) I will always bump it in 2 level increments just to play it safe.
reckless
05-06-2022, 09:45 PM
I was about to bump it from original v1 firmware to v60 directly just fine.
