mdm7266
01-09-2009, 10:07 AM
Hello there! I have i problem with konica 7033. Every morning when i turn it on and it Ready to copy, When i press the copy button, it will run for a moment then it will display the code F28-2. For i know is F28-2 is for abnormal discharge of tranfer HV.
What i will do is to Enter to output code 47-3 to turn-on the HV for some time. when the the machine gets warm, the copier with run in normal condition, as if it has no problem.
So every morning i 'll turn the code 47-3 and wait for 30 minutes or more so that the machine will run and will not display Code F28-2.
I already replaced the Transfer/Separation Assembly, but still same problem occur.
Now I suspect the HV2 is the problem. I have no spare HV2 assy to replaced it. I want to make sure that it is the right problem (HV2 Assy) before i buy one.
is there anyone encountered this problem?
Thanks for the help in advance.
