View Full Version : Konica Minolta C351 Ledger Jamming Intermittent
CopierTechofOmens
01-09-2009, 03:21 PM
11" x 17" jamming. Sometimes doesn't pick up, sometimes, stops before the Reg. roller, sometimes in the fuser. Replaced feed/resist rollers. Cleaned all sensors paper path rollers. Tech bulletin's reccomend, the paper take up sensor. Which is on B/O until Feb.:mad: It also cites
deficiency in the feeding system see attached workaround. :( I don't have any attached workaround. Before I replace the whole feed assembly, is there any of you KM masters that may have this additional info.? (and,or) other solution
masterteknicion
01-10-2009, 02:14 AM
Try putting the felt pads that you would use to clean the print heads on the back right of the cassette where the lever that that the cassette touches to have the paper feed rollers come down further. You are building up the plastic of the cassette that meets the lever to have the rollers come down more.
Setright
01-10-2009, 07:21 AM
What master says should stop the pick-up failure.
Try to decrease the registration loop, I have solved a similar problem with A3 by turning the loop all the way to the backstop (-5).
